Bobman63
May 02, 2024Guide
NETGEAR Orbi (Latest Gen) 970 Series Quad-Band WiFi 7 Mesh Network System
I hooked up my new NETGEAR Orbi (Latest Gen) 970 Series Quad-Band WiFi 7 Mesh Network System. When I installed the unit it updated the firmware automatically. My home is 7200 sq ft. I have the route...
- May 14, 2024
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Bobman63
May 10, 2024Guide
Update
I ended up buying another Satellite which is 3 now with the router for a total of 4. It still has a few spots in the house that are a little slower around 300 mbps here and there. I can walk ten steps forward and get 900 mbps. I am glad I went with this System, but I really don't understand the mesh bad spots. There is mostly good wifi coverage throughout the home now for which I am thankful. I was able to run a cable to the last Satellite I purchased and that really seems to be the ticket.
All in all, I would say this is a good investment for a large home 7200 sq ft or more with thick walls and several floors. I will give this product 4 1/2 stars.
May 14, 2024Guru - Experienced User
Enjoy. 📡
