markfarrell
Nov 24, 2024Follower
Network IP Range
Hello, our router has a starting Ip address of 192.168.10.1 and everything connected to the network (wired and wireless). The Orbi system uses the Range of 192.168.1.1, which in effect then creates 2...
CrimpOn
Nov 24, 2024Guru - Experienced User
Yes, Orbi systems can be placed in Access Point Mode which does what you want. This can be done only from the Orbi web interface. Enter the model number of your Orbi system on this web page:
https://www.netgear.com/support/
Select it from the drop down menu and then select Documentation.
The User Manual will provide instructions on how to switch from 'router' to 'access point' mode.
