Mar 27, 2025Guru - Experienced User
New - RBE771 / RBE770 Firmware Version 10.5.18.3 Released
Bug Fixes: 03/26/2025
Improve 2.4G connection stability
Fixed satellite memory drop issue
Improve after factory reset system boot up time
Download Link:
https://www.netgear.com/sup...
AkWingnut
Mar 27, 2025Tutor
Nothing but issues, I tried to go back to 5.16 and my router was horrible. Nothing worked, hard reset to start over and nothing, tried a new SSID, nothing it was horrible after the update. Ended up hooking up my RBR850 while I deal with the issues with NetGear
Can you give more details on issues and nothing worked?
How did you update the system? Automatic? Manually? Update ALL?
I've been on this version for past 3 weeks and been nothing but good.
