Mar 27, 2025Guru - Experienced User
New - RBE771 / RBE770 Firmware Version 10.5.18.3 Released
Bug Fixes: 03/26/2025
Improve 2.4G connection stability
Fixed satellite memory drop issue
Improve after factory reset system boot up time
Download Link:
https://www.netgear.com/sup...
Can you give more details on issues and nothing worked?
How did you update the system? Automatic? Manually? Update ALL?
I've been on this version for past 3 weeks and been nothing but good.
AkWingnut wrote:
Nothing but issues, I tried to go back to 5.16 and my router was horrible. Nothing worked, hard reset to start over and nothing, tried a new SSID, nothing it was horrible after the update. Ended up hooking up my RBR850 while I deal with the issues with NetGear
AkWingnut
Mar 27, 2025Tutor
Updated the firmware over the weekend, last weekend, Saturday, however I explained to Support that I would reset the router and Sats to get the DeBug Logs they needed for the speeds. Once I did that it went down hill, fast dot com would not load, speed test dot net would not load various web pages would not load, in chrome. Wife's iphone websites would not load if she was connected to the network. I have setup a drive for RnD to grab the needed logs. I ran tests on 3 different laptops, using A7000 adapter, surface pro 7 and my custom home built PC it was bad.
- FURRYe38Mar 27, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Who is your ISP your connected with?
Are you using IPv6 with the ISP or is that disabled on the RBR?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter and Admin Logging on the RBR.- AkWingnutMar 27, 2025Tutor
Those are all great pointers, I will try that. I have what we call ACS Fiber, I had them come out and check the line from the street to the house and from the house to the modem everything was perfect. Cat 7 cable, however I switched it to the cable that came with this device. 1 Router 2 Sat, we have talked about this before, I have several cameras, like 15 different ones. If I go to just one 1 Router 1 Sat the speeds to which the Ring cameras connect to either device goes down really bad. It is about 1400sf, Router is on the top floor middle of the house while 1 Sat is in the entryway which is closed off with a metal or steel door, 2nd Sat is located at the rear of the house near the backdoor to cover the rear cameras.
Even hard wired to the router with my Home PC, using Cat 7 cable it will lose internet every now and then, like it just disconnects randomly. Wifi 7 laptops will just lose their connection also, wifi 6e wifi 6 all devices will just drop.
1400sq ft, that's a bit too small for having the RBR and two RBS. The system would be getting too much wifi signal overlap between the units. The RBR alone can handle that size of home.
Having 15 cameras, depending on there resolution, maybe impacting the system as well.
You'll need to turn OFF at least one RBS for now. The other RBS needs to be out at 30 feet if possible from the RBR.
What is the brand and model# of the Fiber ONT and the modem that the RBR is connected too?
