Mar 27, 2025Guru - Experienced User
New - RBE771 / RBE770 Firmware Version 10.5.18.3 Released
Bug Fixes: 03/26/2025
Improve 2.4G connection stability
Fixed satellite memory drop issue
Improve after factory reset system boot up time
Download Link:
https://www.netgear.com/sup...
Mikey94025
Mar 27, 2025Hero
FURRYe38 wrote:
NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
Nit - This KB link is broken and leads back to the Netgear Support home page. I couldn't find anything about an Erase button.
Hey thanks for checking that. I see that link and the Nighthawk ERASE button links are also broke. I'll check into this with NG.
For alternative ERASE button use, please refer to this PDF guide:
