Mar 27, 2025Guru - Experienced User
New - RBE771 / RBE770 Firmware Version 10.5.18.3 Released
Bug Fixes: 03/26/2025
Improve 2.4G connection stability
Fixed satellite memory drop issue
Improve after factory reset system boot up time
Download Link:
https://www.netgear.com/sup...
AkWingnut
Mar 27, 2025Tutor
I've performed a factory reset, deleted the device from the app, setup new SSIDs and it is still horrible, plugged in my RBR850 and boom everything was perfect again.
I would use a wired PC and web browser to setup the system. This is the PDF process I use when doing a FR and setup from scratch:
However again, the 770 is a bit different from the AX series and for that size of home, having too many RBS maybe one cause of your problems.
- AkWingnutMar 27, 2025Tutor
After updating the FW using a wired connection, I then did a FR, completed the initial setup for the router using the APP, then used the web browser to sync both Sat. I do not have an issue with using only one Router and one Sat, just seems as if it makes no difference in anything, at first my WiFi 7 laptop would get amazing speeds, then after a few updates those speeds dropped to like 50meg, before 1.5gb speeds.
- FURRYe38Mar 27, 2025Guru - Experienced User
What brand and model is the laptop with WiFi7 support?
Brand and model# of the wifi7 adapter in this laptop?
Does the RBRs connected devices show the laptop connecting to both 5+6Ghz or only one frequency?
MSI Raider Laptop with Killer WiFi 7, MSI Raider Laptop Killer WiFi 6e, Lenovo with WiFi 6, used a USB NetGear A7000 WiFi 6/6e adapter, wifi speed decent.
But again, once I went back to the RBR850 all laptops performed at better speeds, no issues, my son's Lenonvo Wifi 6 had a ping of 40ms to 100ms before on the 700 his ping was 500+
