Mar 27, 2025Guru - Experienced User
New - RBE771 / RBE770 Firmware Version 10.5.18.3 Released
Bug Fixes: 03/26/2025
Improve 2.4G connection stability
Fixed satellite memory drop issue
Improve after factory reset system boot up time
Download Link:
https://www.netgear.com/sup...
mysticflounder
Mar 28, 2025Aspirant
Why does my app report no new firmware even though I'm on v10.5.13.1?
Why does the settings screen in the app take 20 seconds to load?
Why do I need to manually check for updates in the first place? Why isn't this automatic?
Mar 28, 2025Guru - Experienced User
Be sure you setting for checking for updates is enabled.
NG may not push new FW to everyone all at the same time. Some maybe pushed in small batches.
Either manually load FW or you can way for it to come down automatically. No idea when that would be.
