Mar 27, 2025Guru - Experienced User
New - RBE771 / RBE770 Firmware Version 10.5.18.3 Released
Bug Fixes: 03/26/2025
Improve 2.4G connection stability
Fixed satellite memory drop issue
Improve after factory reset system boot up time
Download Link:
https://www.netgear.com/sup...
orbicentennium
Apr 01, 2025Tutor
After automatic upgrading to 10.5.18.3 I lost IPv6 connectivity on WLAN clients and also on the computers connected with RJ45 to satellites.
The system is running in AP mode so it should not "touch" the traffic.
It worked before the update.
In addition my home network does not have DHCP6 nor Router Advertisement enabled, as I prefer to issue the IPv6 addresses and gateway manually to only the devices that I want to have IPv6 enabled on. This has been working with the previous Firmware versions.
