Nov 22, 2023Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.10.1.4
New Features and Enhancements: 10/22/2023
Satellite connection and display improvements
WiFi stability improvements
Security Fixes:
This firmware addresses security vulnerabilities....
Straq
Nov 24, 2023NETGEAR Expert
Hi There,
Engineering Team here, V9.10.1.4 is a huge improving from V9.10.0.2 where V9.10.0.2 will it increases stability on client connectivity by ensure network stability takes priority.
Also note, that V9.10.2.3 has came out but it is not mandatory for users to update. Users have option to update right away. This firmware has a bigger fix that allows client to remain connected to network system without the network system crashing or dropping from network. Please let me know if have any questions. Release note for each firmware will come out few days after firmware release usually. We allow users to update so they have a better experience. For new installations, we automatically make the user go to V9.10.2.3 to help with the onboarding experience and make sure they have the latest security and stability fixes.
SporadicWifi
Nov 25, 2023Tutor
Can someone point me in the right direction to download V9.10.2.3? It is not showing up on the product support download for RBE973, Orbi App, or under orbilogin.com. I’ve tried VPN, clearing cookies, everything I can think of.
- FURRYe38Nov 25, 2023Guru - Experienced User
If it's not showing in the Orbi app or RBR web ui, you'll need to be patient and wait for NG to get it online.
- dglsmcd_USMCNov 30, 2023Luminary
The only way currently to update to the subject firmware is to do a factory reset on the satellites first then your router last. Basically you are doing a new setup like it came out of the box. Using the Orbi app to do the setup when it gets to checking for the latest firmware it should give you the option to updating the firmware to V9.10.2.3_1.1.13. Hope this helps!
