Nov 22, 2023Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.10.1.4
New Features and Enhancements: 10/22/2023
Satellite connection and display improvements
WiFi stability improvements
Security Fixes:
This firmware addresses security vulnerabilities....
SporadicWifi
Nov 25, 2023Tutor
Can someone point me in the right direction to download V9.10.2.3? It is not showing up on the product support download for RBE973, Orbi App, or under orbilogin.com. I’ve tried VPN, clearing cookies, everything I can think of.
dglsmcd_USMC
Nov 30, 2023Luminary
The only way currently to update to the subject firmware is to do a factory reset on the satellites first then your router last. Basically you are doing a new setup like it came out of the box. Using the Orbi app to do the setup when it gets to checking for the latest firmware it should give you the option to updating the firmware to V9.10.2.3_1.1.13. Hope this helps!
