Mar 06, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.11.1.1 Released
Enhancements; 03/06/2024
WiFi and backhaul stability improvements
System stability improvements
Bug Fixes:
Fixes a bug where unexpected interfaces display
Fixes a bug where incorrect ...
ApexWifi
Mar 11, 2024Tutor
Im experiencing disconnects with a MacBook Pro. No change from the previous firmware.
Mar 11, 2024Guru - Experienced User
Does this happen with RBS turned off?
Is this the only device that this is happening too?
What OS is loaded on the Mac Book Pro? What model # mac book pro is this? Year?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
