Jun 03, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.3.3 Released
New Features: 06/03/2024
Adds support for SG region
Adds FW anti rollback for SG region
Enhancements:
WiFi and backhaul stability improvements
System stability improvements
Topology...
Labrat3
Jun 04, 2024Star
Thank you for the much-awaited update. I was beginning to think we had been forgotten about.
Will post an update if I encounter any issues. But thus far things seem quite reliable.
I did a Speedtest using Orbi app to get speeds to my router and then tested to my computer over WiFi7 to see how much of that I can get over WiFi. Looking great and better than the throughput I was getting on the old firmware (not sure yet if that is meaningful).
I have XFinity Gigabit X2 with 2000DL/200UL
Speedtest on Router: 2308/239
Speedtest on Wifi7 Laptop within 20 feet of router: 1532/239, Ping: 9
Speedtest on iPhone 15Pro (WiFi 6E) within 20 feet of router: 1333/237 Ping: 17
Jun 04, 2024Guru - Experienced User
Glad you got it updated. Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- SpeedPro_03Jun 21, 2024TutorI’ve seen an improvement using the iPhone 15 Pro Max but I still get some wifi drops and disconnections every 2-3 days and the only fix to reconnect is toggle wifi off for some seconds and back on. Kind of weird but overall works very good.
- FURRYe38Jun 24, 2024Guru - Experienced User
What iOS is on the iPhone?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and RBR and RBS been performed since last update?
SpeedPro_03 wrote:
I’ve seen an improvement using the iPhone 15 Pro Max but I still get some wifi drops and disconnections every 2-3 days and the only fix to reconnect is toggle wifi off for some seconds and back on. Kind of weird but overall works very good.- SpeedPro_03Jun 25, 2024Tutor
What iOS is on the iPhone? iOs 17.5.1 iPhone 15 Pro Max
Mitrastar GPT-2841GX4X5 / Movistar España 1gb fibra simétrica
How many RBS are deployed? 4
What is the size of your home? Sq Ft? 350
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰20 meters
Does this happen with the RBS turned OFF? No
What channel configurations are currently set on the router? 2.4 ghz channel 1 / 5 ghz channel 40
Any Wifi Neighbors near by? If so, how many? Not close enough to affectHas a power off for 1 minute then back ON with the ISP modem and RBR and RBS been performed since last update?
Yes and wifi drops still happen every 2-3 days
