Jun 03, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.3.3 Released
New Features: 06/03/2024
Adds support for SG region
Adds FW anti rollback for SG region
Enhancements:
WiFi and backhaul stability improvements
System stability improvements
Topology...
ZeroSeek
Jun 06, 2024Aspirant
I've followed this manual update because I kept getting Wifi drops. The updates were succesfull, however my RBE970 sattelite seems to be stuck in 2.4 GHZ now and I don't know how to fix it. The satus says "good". I tried resetting it but it keeps staying on 2.4 GHZ. Router and Satellite are only 5-10 meters apart.
- FURRYe38Jun 06, 2024Guru - Experienced User
Does this appear on the RBR and RBS web pages?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Wait about 10 minutes then check the RBS.
- ZeroSeekJun 06, 2024Aspirant
Thankyou! This fixed it, much appreciated!! Satellite connetion finally says: "5GHz + 6GHz".
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
