Jun 03, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.3.3 Released
New Features: 06/03/2024
Adds support for SG region
Adds FW anti rollback for SG region
Enhancements:
WiFi and backhaul stability improvements
System stability improvements
Topology...
Jun 24, 2024Guru - Experienced User
What iOS is on the iPhone?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and RBR and RBS been performed since last update?
SpeedPro_03 wrote:
I’ve seen an improvement using the iPhone 15 Pro Max but I still get some wifi drops and disconnections every 2-3 days and the only fix to reconnect is toggle wifi off for some seconds and back on. Kind of weird but overall works very good.
SpeedPro_03
Jun 25, 2024Tutor
What iOS is on the iPhone? iOs 17.5.1 iPhone 15 Pro Max
Mitrastar GPT-2841GX4X5 / Movistar España 1gb fibra simétrica
How many RBS are deployed? 4
What is the size of your home? Sq Ft? 350
20 meters
Does this happen with the RBS turned OFF? No
What channel configurations are currently set on the router? 2.4 ghz channel 1 / 5 ghz channel 40
Any Wifi Neighbors near by? If so, how many? Not close enough to affect
Yes and wifi drops still happen every 2-3 days
- FURRYe38Jun 25, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...For the size of home, the RBR and maybe two RBS would be needed. Can you turn OFF two RBS and test with just the RBR and TWO RBS only?
20 meters maybe a bit too far. Try 15 meters between the RBR and RBS?
- SpeedPro_03Jun 26, 2024TutorThanks I will try that out and let you know!
- FURRYe38Jun 26, 2024Guru - Experienced User
