Nov 12, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.4.16 Released (for NA Region Only)!
New Features: 11/12/2024
Added Router Protection support.
Added Satellite Notification support.
For NA Region Only
Enhancements:
Improved WiFi and backhaul stability.
Improved syste...
prowl2000
Dec 10, 2024Aspirant
I updated my firmware a couple days ago via the iPhone app. Yesterday and today I'm seeing that my two Macs are no longer able to connect via WIFI. I can connect via ethernet no problem. I look in the logs on the router and I do not see any issues.
Is this a case where I should perform a factory reset?
- FURRYe38Dec 10, 2024Guru - Experienced User
First try a power OFF of the system for 1 minute then back ON.
What channels are you using on the RBR?
What two Macs do you have? OSX versions?
What region are you located?
- prowl2000Dec 10, 2024Aspirant
Thanks for the quick reply. I've powered down all systems and restarted. Still nothing.
2.4 is on auto, 5GHz set to 40.
Mac 1 is a MacMini 2014 running OS 12.7.6
Mac 2 is a MacBook intel 2020 running OS 15.1.1
Region is US, so NA.- FURRYe38Dec 11, 2024Guru - Experienced User
And you don't have any Access Controls or Armor or SPC enabled?
I have a Mac Book Pro 2018 and it connects to mine fine. OSX 12 and 15.
I do need to check my Mac Mini 2012.
