Nov 12, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.4.16 Released (for NA Region Only)!
New Features: 11/12/2024
Added Router Protection support.
Added Satellite Notification support.
For NA Region Only
Enhancements:
Improved WiFi and backhaul stability.
Improved syste...
Dec 10, 2024Guru - Experienced User
First try a power OFF of the system for 1 minute then back ON.
What channels are you using on the RBR?
What two Macs do you have? OSX versions?
What region are you located?
prowl2000
Dec 10, 2024Aspirant
Thanks for the quick reply. I've powered down all systems and restarted. Still nothing.
2.4 is on auto, 5GHz set to 40.
Mac 1 is a MacMini 2014 running OS 12.7.6
Mac 2 is a MacBook intel 2020 running OS 15.1.1
Region is US, so NA.
- FURRYe38Dec 11, 2024Guru - Experienced User
And you don't have any Access Controls or Armor or SPC enabled?
I have a Mac Book Pro 2018 and it connects to mine fine. OSX 12 and 15.
I do need to check my Mac Mini 2012.
Region is US, so NA.- prowl2000Dec 11, 2024Aspirant
Nothing is installed on either Mac. What is strange is appears to be working today on the laptop, I haven't tried the mini yet. I wonder if there was an ip address contention or something. I'll keep monitoring it.
Might check the logging on the RBR to see if those computers are appearing in it's log for DHCP IP address.
