Dec 26, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.5.3 (All Regions!)
Enhancements: 12/26/2024
Improved 2.4 GHz WiFi connectivity.
Bug Fixes:
Fixed an issue where the 2.4 GHz channel did not change when using channels 9-13.
Fixed various minor bugs.
S...
wvkregten
Jan 26, 2025Luminary
Works fine in eu just updated
Mooose
Jan 27, 2025Luminary
Note that there is now a version of 9.12.5.3 that is not "NA only":
https://kb.netgear.com/000066513/RBE970-RBE971-Firmware-Version-9-12-5-3
- SpeedPro_03Jan 27, 2025TutorIs the NA version the same file as the non NA version? I am in Europe and installed the NA version some weeks ago,m and I’m not sure if I have to reinstall the non NA version if it has changed anything. Thanks
- FURRYe38Jan 27, 2025Guru - Experienced User
I believe this version is now all NA and ROW supporting. I see the download site for this version was updated on 1/6/25 and NA Region Only was removed.
SpeedPro_03 wrote:
Is the NA version the same file as the non NA version? I am in Europe and installed the NA version some weeks ago,m and I’m not sure if I have to reinstall the non NA version if it has changed anything. Thanks- SpeedPro_03Jan 27, 2025TutorOk so better update again?
