Dec 26, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.5.3 (All Regions!)
Enhancements: 12/26/2024
Improved 2.4 GHz WiFi connectivity.
Bug Fixes:
Fixed an issue where the 2.4 GHz channel did not change when using channels 9-13.
Fixed various minor bugs.
S...
Feb 25, 2025Guru - Experienced User
Your system serials may not be in the Auto Update system. NG rolls updates out in batches as well.
I prefer to manually update and have never had problems manually updating FW. RBS first, then RBR lastly using a wired PC.
Is the system working currently? If so, might just keep what it loaded on it for now.
Eriksen76
Apr 28, 2025Apprentice
Works fine here since update
