Dec 26, 2024Guru - Experienced User
New - RBE970 / RBE971 Firmware Version 9.12.5.3 (All Regions!)
Enhancements: 12/26/2024
Improved 2.4 GHz WiFi connectivity.
Bug Fixes:
Fixed an issue where the 2.4 GHz channel did not change when using channels 9-13.
Fixed various minor bugs.
S...
OrbiTechDude
May 20, 2025Apprentice
Apologies for the delay in a response regarding the situation you and I were previously discussing
A lot has been done since the last time we chatted, so I’ll bring you up to speed. I ended up replacing all cabling within the network and ensured proper bend radius because my ISP I am finding is highly incompetent when it comes to equipment installations. I also replaced the Ubiquiti Nanostations that were servicing as my PTP to Ubiquitui Wave Picos (much more suitable for the speeds and to eliminate so much 5ghz bands running that were most likely adding interference). After doing so, I do have speeds solidly at 300DL, 50UP (my plan).
However, there seems to be a universal bug in this firmware that applies to all Apple devices or at least the Apple Devices I possess. It doesn’t matter what WiFi channel I choose, also doesn’t matter if I turn off private address and turn off limit up address tracking, but I’ll get the 300mbps for a good duration, and after I leave my house and come back from work, the devices seem to have a partial failure establishing a connection to the Orbi and when it then does, it caps the DL at half, with upload still maxed. However, if I spam turning on and off the Wi-Fi of the device, the device begins to then get 300DL again, 70up. I do want to mention if I reboot the router, it fixes it, but only for a breif moment where apple devices and the Orbi misbehave. I do notice the Orbi app keeps notifying me every so often when an Apple device attempts to reestablish a connection. I don’t know if that’s intentional since it says it’s a “new device”, but if memory serves right, once a device connects and is offline, it should stay in the device list but just display the status as “offline” in the app?
Apple Devices experiencing intermittent caps include (in which the temporary and annoying workaround applies to), but are not limited to:
- Apple TV 4K (2 total, both affected)
- iPhone 12 Pro
- iPad Pro (11-inch) (2nd generation)
- 2020 MacBook Pro 13″ w/ Touchbar
Now, one HUGE issue I see with this firmware is that anytime I add in a satellite that is to be on wireless backhaul, THE ENTIRE network gets capped at 100-150DL. This firmware is buggy as hell. Hard resets of Orbi satellites and the router itself do not fix that issue and I’ve even tried hard resetting and starting from scratch.
Netgear has gone long enough with Apple woes and to a point, a lot of it was Apple’s fault, but Apple has since corrected a majority of those problems and for being a $2K Wi-Fi Mesh system, all owners of it should have zero issues with Apple devices moving forward.
As far as my system being compatible with the Tarana, it appears it’s completely fine, but could be worth Netgear taking a look. I am not running a port switch between my ISP’s Tarana and the Orbi Router and speeds have been consistent since I fixed cabling and interference issues, but I do think Netgear may want to examine and confirm complete compatibility by working with Tarana on this. Also, it does output gigabit full, but it’s auto negotiation. To clarify, it’s auto negotiation at gigabit full only. It’s not a hardcode to gigabit full. If one does that, the link will fail. I only know this as I also tried the Orbi in AP mode with a MikroTik Hex as the router and while the router was amazing, the damn Orbi kept dropping the network almost every day, so I went back to router mode. I need a Netgear engineer in here and we need to start working on a firmware fix or a beta firmware at least for me.
Anyway I can get into beta firmware tests and test things out. I do IT for a living and love to troubleshoot and works towards a solution. Let me know if you need any clarification or have some things for me to try.
PS: That RMA was green lighted and I am running the replacement system currently.
Best,
Jaryn
OrbiTechDude
May 21, 2025Apprentice
Straq , please advise on how to proceed with this. I think we need to work together on this.
- wvkregtenMay 21, 2025Luminary
Maybe time for fw update, its been a while
- OrbiTechDudeMay 21, 2025Apprentice
Agreed. I feel like they are indeed getting closer to resolving most annoyances, but not close enough.
- MoooseMay 21, 2025Luminary
Agreed. I gave up on the support thread after it had gone around in circles for a while, and they started asking for screen shots, personal information and other irrelevant details. It is ridiculous that I have spent this much money with the expectation of stable wifi and still have to tell the children to "just disable wifi and use 5G instead" when they get thrown out of their Pokémon battles mid-fight.
To be honest, this is exactly how the RBK50 systems were. Really buggy at the start, and then slowly got solidified. I had the RBK50 system, with the outdoor one and the RBW30 at the time. My network was already fast and stable after their initial hurdles. Hell, I remember telnetting (back when telnet was allowed in those times) to get that system running. It's looking like this RBE970/1 model is going to go down the same pathway. Long term I know it will be worth it, but I genuinely have to ask why the hell it is taking so long for Netgear to fix issues with Apple devices. You would think that would be a priority given that Android and Apple are pretty much staple devices that will almost always be in one's household!
If I had direct access to engineers, I could help them pinpoint issues much quicker and most likely get firmware patches released to everyone wuicker, which would probably boost their sales and make everyone a whole lot happier!
One thing I think I have learned from first-hand experience and from researching the countless posts here is that for whatever reason these RBE970/1 units are ultra-sensitive to cabling. If you do your own cabling, you should at minimum use Shielded Cat6A cable (STP preferred, not F/UTP) and you MUST ensure your terminations are the absolute tightest they can be.
