Mikey94025
Mar 14, 2025Hero
New RBE870/RBE871 firmware - 10.5.17.3
A new firmware version has just been posted for the Orbi 870 line: https://kb.netgear.com/000066609/RBE870-RBE871-Firmware-Version-10-5-17-3. This firmware release updates the initial firmware release version 10.5.13.6 when the Orbi 870 line launched in January. Its release notes say:
Bug Fixes:
Fixed satellite memory leak issue
Fixed satellite status is stuck in config sync or optimizing
I am optimistic that this new firmware mentions fixing satellite issues. Over my 2 months of ownership I've noticed a few times some satellite performance/connectivity issues after running for a while. They were resolved after restarting my 2 satellites. I did not contact Netgear and just waited for a firmware update.
I manually installed 10.5.17.3 and will see how it goes. It's running fine for me now.
Mikey94025 wrote:I am optimistic that this new firmware mentions fixing satellite issues. Over my 2 months of ownership I've noticed a few times some satellite performance/connectivity issues after running for a while. They were resolved after restarting my 2 satellites. I did not contact Netgear and just waited for a firmware update.
Unfortunately after up for 40 hours, my v10.5.17.3 satellite's speed on my iphone pro 15 still went to less than 1 Mbs. If I sit near my base router the same iphone measures 800+ Mbs. This is measured using the Speedtest iphone app. My wired devices to the satellite seem unaffected, so it appears to only an issue for clients connected to the satellite..
I will file a support case with Netgear.
More debugging notes (when the satellite has been up for a while and performing poorly):
- Confirmed devices wired to the satellite are fine
- Connecting to the satellite's website shows zero devices in Connected Devices. This is unexpected since I know there are wired devices and orbilogin.com website shows them connected to the satellite.
- Wireless clients may not be connecting to any satellite. I have the Orbi 870 3-pack so 2 satellites. Orbilogin.com website doesn't show any wireless devices connected to the problematic satellite or my other satellite. This would explain the poor wireless speedtest results because my base router is 2 floors away in my house. I suspect all my wireless clients are connecting only to the base router after the satellites are up for awhile.
- Restarting the satellite (power cycle) restores wireless performance and wireless clients according to both orbilogin.com website. The satellite's Connected Devices list also reappears, now showing wireless and wired clients again.
