youngek
May 24, 2024Aspirant
New Setup upgraded firmware RBE970 / RBE971 Firmware Version 9.11.1.1no longer have wifi6
Hello, I setup my orbi WIFI7 network yesterday. Upgraded to the latest firmware. I noticed that I no longer have wifi6 ghz. I see in the wireless setting 2.4 and 5ghz but 6 is missing. I have un...
May 24, 2024Guru - Experienced User
NG removed the separte 6Ghz adjustment from the UI so it's still there, and 6Ghz is running on the main WLAN network along with 2.4 and 5Ghz. Your 6Ghz devices should connect to the 6Ghz signal if they support it and signal is good. It's all automatic currently.
youngek
My iphone 12 max pro and laptop which has a wifi6 card is getting about 5 to 600dl and from my modem to the orbi its 2.5gb. So that connection is good. its the orbi to my devices it is slower. Am I wrong that I should be seeing at least 1gb dl?
- FURRYe38May 24, 2024Guru - Experienced User
My iphone 12 Pro Max hasn't seen much over 700-800Mpbs. It's not 6Ghz supporting.
If your WiFi6 card supports 6Ghz, you should see over 1Gb if the connection and signal quality is good. I know I see near 900Mpbs with my two AX and BE cards I have. But my ISP only has 1Gb support.
