ColinRutherfor
Mar 01, 2024Follower
No internet access
Hi, The internet is not working on Chrome on my PC. I just set up the Wifi with Orbi 970 Series Quad-Band WiFi 7 Mesh. Before installing the Wifi, I can easily access the network. But now why it does...
Mar 01, 2024Guru - Experienced User
Do other devices work with the 970 wifi?
What is the wifi brand and model # adapter thats in this PC?
Does the PC have a ethernet adapter connection you can try?
Be sure all wifi and ethernet adapter drivers are up to date from there support sites.
Make contact with the PCs mfr for help and support information regarding there product.
