angrynor
May 18, 2024Aspirant
No internet on guest network connected via Satellite
After spending a lot of money on Orbi 970 + 2 satellites because I needed a guest network where a lot of people could connect, it is very disappointing to know that it doesn't work. It took me hou...
angrynor
May 23, 2024Aspirant
Wirelessly.
May 23, 2024Guru - Experienced User
I recommend you give this reset process a try:
IF this fails to get Guest Network working thru the RBS, I would open up a support ticket with NG and ask about an RMA.
- angrynorMay 24, 2024Aspirant
Will have to do it when I am expecting a down period of the usage.
Disappointing but thanks for the suggestions!- FURRYe38May 24, 2024Guru - Experienced User
I'll load up mine and check as well.
Keep us posted on this.
Had a chance to put my 970 series online today. Only tested with one RBS however a iPhone, Mac Book Pro and Android pad all connected to the GN and was able to get internet and stream data.
