romsbri
Jan 04, 2025Aspirant
No WIFI connection Nintendo Switch & Orbi RBE773
Dear community, I just bought the BE11000 Mesh WiFi System (RBE773) system, I succeed to reconnect all my network devices (smartphone, Sonos speakers, printers, desktop, Sony PS5..), except the N...
- Jan 04, 2025
thanks FURRYe38 for taking time to answer to my question, after investigating on Nintendo forum, I found the way to reboot the switch (I'm not an expert for that) and after this reboot (press a long time on power button), my SSI has appeared and I was able to connect it correctly...
the problem is solved.
Jan 04, 2025Guru - Experienced User
Orbi BE system support AES encryption. WEP is out dated and compromised years ago and no supported on Orbi systems.
Trying to connect to the main WLAN or have you tried the separate IoT network?
Ya, make contact with Nintendo as well.
romsbri
- FURRYe38Jan 04, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
