romsbri
Jan 04, 2025Aspirant
No WIFI connection Nintendo Switch & Orbi RBE773
Dear community, I just bought the BE11000 Mesh WiFi System (RBE773) system, I succeed to reconnect all my network devices (smartphone, Sonos speakers, printers, desktop, Sony PS5..), except the N...
- Jan 04, 2025
thanks FURRYe38 for taking time to answer to my question, after investigating on Nintendo forum, I found the way to reboot the switch (I'm not an expert for that) and after this reboot (press a long time on power button), my SSI has appeared and I was able to connect it correctly...
the problem is solved.
romsbri
Jan 04, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
