Jarvis-2009
Jan 16, 2024Tutor
On teams meetings connection dies and then reconnects
I've been having the same issues. On teams meetings connection dies and then reconnects. Kids in the middle of gaming connection dies and they get kicked out. Firmware is up to date. Spoke to sup...
Jan 16, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Is SIP ALG Enabled or Disabled on the RBR? Try the other setting as a quick test.
Please make contact via PM with Straq
Jarvis-2009
Jan 16, 2024Tutor
Thanks for the reply
It’s Verizon fiber. 1gig Cables are good.
1 main router and 1 satellite
House 3600 square feet strong signal everywhere. Appropriate spacing between RBS.
SIP ALG disabled.
Have not tried to turn satellite off and see if it happens.
SIP ALG disabled.
- FURRYe38Jan 17, 2024Guru - Experienced User
What is the cable CAT# version?
SIP ALG disabled. Try with SIP ALG Enabled?
Let us know if this still happens with RBS OFF.- Jarvis-2009Jan 17, 2024Tutor
In testing now with RBS off for the next few hours. - Will advise.
- brianldJan 17, 2024Apprentice
I'm glad someone else was having this issue. I noticed this the other day - was on an active Teams call on my phone, moving around the house, and it would frequently cut out (die & reconnect). FWIW, I am not on the GA firmware, but rather a newer version that Straq provided. Will also drop him a note.
- Jarvis-2009Jan 17, 2024TutorA few hours with the satellite off with no issues.
- FURRYe38Jan 25, 2024Guru - Experienced User
New FW available:
