Jarvis-2009
Jan 16, 2024Tutor
On teams meetings connection dies and then reconnects
I've been having the same issues. On teams meetings connection dies and then reconnects. Kids in the middle of gaming connection dies and they get kicked out. Firmware is up to date. Spoke to sup...
Jan 16, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Is SIP ALG Enabled or Disabled on the RBR? Try the other setting as a quick test.
Please make contact via PM with Straq
Jarvis-2009
Jan 16, 2024Tutor
Firmware is the latest version available on the website.
