jer22
Feb 06, 2024Aspirant
Orbi 7 - would it stop my problems with Nighthawk xr500
I have a nighthawk XR500 connected to a eero (for my ring system) and a 16 port hub in a 2000 sq ft ranch with a finished basement. I dont do much gaming, but have a lot of wireless smart home item...
JWS9518
Feb 06, 2024Luminary
An Orbi type system would help you manage a large number of devices or even one of the latest high-end routers would also help with that for a bit less money. It depends on what your budget is though as both would be good choices.
I would also suggest making sure you have your firmware updated on your current router and all other connected devices before making that choice as older firmware could also be an issue too.
