gvlierop
Apr 08, 2024Aspirant
Orbi 7 Wired backhaul and Aruba 6100 Managed switch
Hi All, I just received my brand new Orbi Wifi 7 Router and 3 satellites. I set the satellites up first in wireless backhaul after updating to the latest firmware (v9.12.2.1) on all devices. Too...
- Apr 08, 2024
That's a smart switch, aka, managed so no.
Any switch with characters after the ### in the model name is a smart/managed switch or having some form of management user interface with features that can be changed.
The MS105 of that series is non managed so could work. I don't have this model. My XS505M and GS110MX are non-managed switches and work. The GS110MX seem to be the only series with characters after the model number that's not a managed or smart switch.
Apr 22, 2024Guru - Experienced User
Wired backhaul is broke if a managed switch is in the mix. I've tested this one as well with my NG108T switch. Horrible RBS behaviors are seen, WEB UI and Orbi app do not work right for the RBS. Nothing will connect to the RBS. Guest Network breaks as well.
NG is already aware of the issue. Hoping they will fix it soon.
gvlierop
Apr 22, 2024Aspirant
Yep, all the same with mine.
Also the Webui and App are v e r y s l o w w or need to be restarted to see stuff.
Come on NG, fix this soon please.
We pay enough money for your products compared to the competition like TP-Link.
- jabenedicicApr 22, 2024TutorYou using it in AP or Router mode? Which port did you have connected to the switch?
In my testing I couldn’t get wired backhaul to work in AP mode at all regardless of what type of switch (just going back through my notes), tested it with both MS510TXM and GS308.
In Router mode I could get the wired backhaul to work across both switches, but with the managed switch I had some issues getting DHCP to work via the wired backhaul.
I have a suspicion it’s related to AP mode, but that’s only anecdotal based on the testing and debug work I’ve done with NG support so far. I have a remote session with engineering coming up hopefully in the next week or so, maybe that will be useful.- gvlieropApr 23, 2024Aspirant
It was in AP mode. Tried all ports 😉
With the managed switches it just didn't work. After connecting non-managed switches, all workes fine for me for now.Just waiting for NG to solve the managed switch problem.
Only the one satellite that is on Wifi backhaul sometimes needs to reconnect en sync. Don't know why its doing this resymc? Maybe channel switching?
- FURRYe38Jun 14, 2024Guru - Experienced User
