njweb
Jan 19, 2025Luminary
Orbi 770 - Use MLO backhaul? Use 5Ghz DFS or leave at 40? And Wifi 7 connection issue questions.
 I recently purchased the RBE773 (Orbi 770 3-pack system) - got a nice deal     1) 5 GHz - Use channel 40 (default) or one of the 5GHz DFS channels?  Is there a benefit to changing the 5GHz channel fr...
Jan 19, 2025Guru - Experienced User
MLO is a mode of connection only. If a wifi device supports WiFi 7 and supports 5 and 6Ghz frequencies, the device will connect to both 5 and 6Ghz for a multi link connection. MLO is automatic on all BE series systems. Even on the 770 series, it's in operation. The MLO Backhaul is already working and I believe this user changeable option is no available on newer versions of FW and maybe no longer seen on the 770 series in future FW updates. Again, it's all automatic and based on wifi device support. The MLO Backhaul is NOT accessible by user wifi devices and only by the RBS when wirelessly connected.
Note that you need a device that support WiFi7 and installed on a OS that supports WiFi7 specs. Windows 11 24H2 only supports this feature. Windows versions lower then that do not.
Is there a benefit to changing the 5GHz channel from '40' to one of the 5GHz DFS channels? Or is there a reason the 5GHz channel is set to 40 by default (related to wireless backhaul perhaps)?
While I read some posts about Wifi 7 and that the Orbi settings cannot be changed (and hence the admin screen settings only shows 2.4GHz and 5GHz and does not refer to Wifi 7), I have a few questions related to Wifi 7:
2) Wifi 7 - How to check that Wifi 6E and Wifi 7 are even working on the Orbi 770/970?
In the Orbi admin (192.168.1.1) screen, I do NOT see any reference to Wifi 7? I do not even see 6GHz noted, except for the satellites under Attached Devices? For the satellites, it shows 'Connection Type", "5GHz + 6GHz".
But even then, that could be Wifi 6E and not Wifi 7.
There is no explicit confirmation in the screen that the router or satellites even have Wifi 7 band enabled / in use?
Any insights would be appreciated, thanks!
3) Wifi 7 USB adapter connecting to 5 Ghz and not connecting to Wifi 6E or Wifi 7?
I have a Wifi 7 (Realtek 8912AU) USB adapter, but I see it is connected to the 5GHz band and not 6 GHz.
Shouldn't my Wifi 7 adapter connect to Wifi 7 by default (assuming signal strength is strong enough)?
4) MLO Backhaul - Under 'Advanced' > 'Advanced' (again) > 'Advanced Wireless Settings', I see the following option (disabled by default). What are the pros and cons of enabling MLO Backhaul?
Advanced Wireless Settings (MLO Backhaul) Enable 240MHz Bandwidth
Thanks in advance for any insights or recommendations for the above questions!
- njwebJan 19, 2025LuminaryThanks a lot Furry! MLO: Thanks! Interestingly I am pretty sure I have the latest 770 firmware, but I will double check. V10.5.13.1_2.2.34 Wifi 7 - Thanks. Yes, I had previously read that Win 11 24H2 was required for Wifi 7. I upgraded to 24H2 yesterday in fact (only after it seemed some of the 24H2 issues had been resolved). - njwebJan 26, 2025LuminaryJust played around with it today and my Archer TBE6500UH Wifi 7 USB adapter is still only connecting to the Orbi 770's 5 GHz network. Perhaps this is expected behavior, but would have expected it to connect to the 6GHz band? - CrimpOnJan 26, 2025Guru - Experienced UserOther WiFi adapters used on Windows 11 have settings for which WiFi band to prefer. (Right click on the adapter in Windows Network Devices and select Properties.) Does this TP-Link adapter have options for how to connect? Do you happen to have any other devices which support the 6GHz frequency band?
