Robiswrkn
Apr 21, 2025Aspirant
Orbi 770 AP mode with satellites
Hi - I purchased the Orbi 770 3 pack. My ISP needs it's gateway to be the router. So I set the base unit to access point mode (AP). I cannot get the satellites to work/connect. I tried the sync ...
- Apr 22, 2025
You said you had the switch connected behind the gateway router...Move the switch connection to behind the RBR:
Gateway router LAN port connected to Yellow WAN port on RBR<>RBR in AP Mode>Switch connected to a open LAN port on the RBR<>RBS connected to switch.
What brand and model# is this switch?
Robiswrkn
Apr 22, 2025Aspirant
I think that is how I am set up. If not, tell me what to move?
Apr 22, 2025Guru - Experienced User
