CaidlyReally
Aug 19, 2024Aspirant
Orbi 770 Compatible Satellites
(First, I did search...) Think this is a good place to post known compatible satellites with the (new) Orbi 770 Home Mesh system (RBE770/771). SO far, I have been able to confirm: RBS750 P...
Aug 19, 2024Guru - Experienced User
CaidlyReally
Thank you for that chart link.
It is still not updated (as far as I could read) with the RBE770/771.
Hope it will build soon.
- FURRYe38Aug 19, 2024Guru - Experienced User
Just because the RBS750 series works, may not mean that NG will support it. NG has been known to close those doors later on in FW updates.
