nadrux
Dec 27, 2024Tutor
orbi 770 connections issues + a strange ssid
Hi everyone, sorry i dont speak well english so i used chat gpt to translate and make the sentence more understandable I recently upgraded from the Orbi 760 to the Orbi 770, and I’m facing some frus...
Dec 27, 2024Guru - Experienced User
KevinLiT is exactly correct. what firmware version are you on?
some of the older/pre-release versions did have the mac broadcast with the ssid. That was pretty quickly fixed.
- FURRYe38Dec 27, 2024Guru - Experienced User
The "NTGRBH" is normal for BE series and will be seen. It's not hidden and is secure and not accessbile. Its only the wireless backhaul signal between the RBR and RBS. NG is aware of it and no idea IF or when they will make it hidden.
