crowe2024
Sep 22, 2024Tutor
Orbi 770 Mesh devices drop wifi | Wired never drops
I have a 3000 sqft multilevel home, two new 770 Orbi Mesh devices. I have an Orbit on first floor and an Orbit on second at the far end. When in my bedroom which is in between the two devices, my l...
Sep 22, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Where is the Orbi RBR located?
Where is the Orbi RBS located?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
