crowe2024
Sep 22, 2024Tutor
Orbi 770 Mesh devices drop wifi | Wired never drops
I have a 3000 sqft multilevel home, two new 770 Orbi Mesh devices. I have an Orbit on first floor and an Orbit on second at the far end. When in my bedroom which is in between the two devices, my l...
Oct 01, 2024Guru - Experienced User
Any progress on this?
- crowe2024Oct 01, 2024Tutor
Hello and apologies I have not replied, I began working with Netgear support and they have been keeping me busy capturing logs among other testing.
Where is the Orbi RBR located? MIDDLE OF FIRST FLOOR ON A TABLE
Where is the Orbi RBS located? SECOND FLOOR FURTHEREST BEDROOM
What is the size of your home? Sq Ft? 3000 sqft
What is the distance between the router 35-40FT +
Does this happen with the RBS turned OFF? YES
I live in a builder style multi-level home, built in 2015. Mostly open floor plans with minimal walls.
I have tried different locations, I removed my firewalla firewall and have connected the RBR directly to the modem with a new CAT 8 ethernet cable.
I have changed channel for 2.4 as well as the 5ghz, there is not an option to make any 6ghz changes in the orbi.login page.
I purchased another satellite and use it instead of my original, also tried using it as a 2nd RBS for coverage just in case.... Still same drops on laptops, mobiles, tvs. Drops out and within a few seconds reconnects.
I feel like at this time, the issue is isolated to the RBR and I am pushing netgear to allow a warranty claim as it is just over 30 days from purchase date.
I do have a house on each side of me, so that is two homes with wireless as well. I have tried changing channels multiple times in case there is co-channel interference but no progress.
️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite - FURRYe38Oct 01, 2024Guru - Experienced User
If this happens with just the RBR ON alone, possible some issue with the RBR.
Yes, I disconnected the RBS this past weekend and only used the RBR staying with in to have good signal and still experienced the drops. It was no better or worse, same behavior.
