MyriadRocker
Jun 29, 2024Aspirant
Orbi 770 Sats compatible with 970?
We just moved into our house earlier this year and I broke down and upgraded to the Orbi 970 from the super old RBR50. It wasn’t broke so I didn’t fix it. Haha I had the house all wired with Ethern...
Jul 07, 2024Guru - Experienced User
Got a picture of this?
The RBR50 is ethernet connected to the back of the RBR970?
Shouldn't be seen by the 970 series as a satellite...
MyriadRocker
Jul 07, 2024Aspirant
Yep, see below. And yes, it is wired. You'll see that there are 3 satellites connected, but I only have the two satellite system. The second one in the list is the RBR50 and it has been in that Config Sync status ever since I got it hooked up earlier today.
- FURRYe38Jul 07, 2024Guru - Experienced User
Interesting. Possible the FW isn't tuned fully for the RBR50.
Does this one entry disappear if you turn OFF the RBR50 in AP mode?
- MyriadRockerJul 08, 2024Aspirant
It shows up as disconnected like a normal satellite would. Odd.
