JoseLopez
Feb 26, 2025Guide
Orbi 770 Series Help
Hell everyone! I currently use the Orbi RBR750 router + 1 Satellite, which supports Wi-Fi 6. I just purchased a new laptop that supports Wi-Fi 6E, and I am building a new desktop that will al...
- Feb 26, 2025
The improvement would be a getting support for Wifi 7 which supports both 5Ghz and 6Ghz connections at the same time. MLO. 6E only supports single connections at a time. So 5Ghz or 6Ghz at a time, just not together. SLO.
If your 750 series is working for you, could keep it a bit longer until you get something that supports WiFi7 and MLO.
