Paul_S_B
Mar 20, 2025Aspirant
Orbi 770 tri-band speed selection
Hi Folks. I just installed the 3 piece router with two satelites (RBE773 system) and got everything going with a Star copper backhaul except Netgear Arlo Q camera on wifi. Apparently it only uses 2.4...
CrimpOn
Mar 20, 2025Guru - Experienced User
There is no need to force the Orbi into 2.4G mode because it is already supporting 2.4G Orbi WiFi provides a primary WiFi connection called a Service Set IDentifier (SSID) on both 2.4G and 5G frequencies.
https://en.wikipedia.org/wiki/Service_set_(802.11_network) If the Arlo camera has only a 2.4G radio and can detect the Orbi WiFi, then it is detecting the 2.4G. (With no 5G radio, it cannot detect the 5G signal.)
If the Arlo camera is not connecting, I suspect there is some other issue. (I sometimes regret making my WiFi password so complicated because I often have problems entering it on a tiny smartphone screen. Does the Arlo app allow you to display the password instead those horrid 'dots'?)
