Anthony1230's avatar
Anthony1230
Follower
Nov 28, 2024
ORBI 770
When I had Eero, my printers always appeared when I needed to print from my laptop or android phone. With ORBI 770 mesh, this is not the case. I either have to go wake up the HP printer and with the Epson, delete the printer profile and add new printer. Has anybody had these same problems and figured out a solution? I am thinking it may be problem with firewall, but am not knowledgeable enough to know.
  • Straq's avatar
    Straq
    NETGEAR Expert
    Which firmware is your Satellites and Router on?
    Best,
    Straq
  • Mithun_N's avatar
    Mithun_N
    NETGEAR Expert
    Is the printer connected to Orbi system using wired or wireless?
    If wireless, can you please check if the printer is actually connected to orbi Wi-Fi.
    Also, please make sure the phone or the laptop you are using to print is on the same Orbi Network.
  • FURRYe38's avatar
    Any progress on this?
