grTEXpace
Dec 27, 2024Aspirant
ORBI 770Series
Hello All, Wondering if anyone has successfully added a TaHoma Beecon WPA2 Wi-Fi connection to the ORBI771 Router? The Tahoma uses iPhone IOS somfy app to make the Wi-Fi connection. The TaHoma req...
- Dec 28, 2024
Hello FURRYe38, Thanks for your reply. Finally got a reply from ToHoma somfy support and they said WPA2-PSK encryption not supported only WPA2-Personal. Tried the IoT 2.4 GHz only setting, but no go. So decided to use Ethernet connection instead of Wi-Fi. Finally found a micro USB Ethernet adaptor I needed on Amazon. So I'm good to go.
Dec 27, 2024Guru - Experienced User
The Orbi system has a separate IoT network with configurable settings for 2.4 or 5Ghz devices along with wifi security settings that should work. Refer to the IoT mfr's support site for help and information regarding there product and getting it set up.
grTEXpace
Dec 28, 2024Aspirant
- FURRYe38Dec 28, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - raven_auDec 28, 2024Virtuoso
grTEXpace wrote:Hello FURRYe38, Thanks for your reply. Finally got a reply from ToHoma somfy support and they said WPA2-PSK encryption not supported only WPA2-Personal.
So what exactly is the difference between WPA2-PSK and WPA2-Personal?
I'm pretty sure they both use the WPA2 protocol, and they both use a pre-shared key (aka. PSK).
