grTEXpace
Dec 27, 2024Aspirant
ORBI 770Series
Hello All, Wondering if anyone has successfully added a TaHoma Beecon WPA2 Wi-Fi connection to the ORBI771 Router? The Tahoma uses iPhone IOS somfy app to make the Wi-Fi connection. The TaHoma req...
- Dec 28, 2024
Hello FURRYe38, Thanks for your reply. Finally got a reply from ToHoma somfy support and they said WPA2-PSK encryption not supported only WPA2-Personal. Tried the IoT 2.4 GHz only setting, but no go. So decided to use Ethernet connection instead of Wi-Fi. Finally found a micro USB Ethernet adaptor I needed on Amazon. So I'm good to go.
grTEXpace
Dec 28, 2024Aspirant
Dec 28, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
