Crasje
Mar 18, 2025Tutor
Orbi 870 - coverage, question. iPhone/iPad not connected to satellite?
Hello, I was testing my i-net speeds (upgraded from RBR50 to RBR870) with an iphone app and noticed that I was having a low download speed in my office on the 2nd floor being really close to t...
Mar 18, 2025Guru - Experienced User
I usually disable the wifi radio on my Apple devices for 5 seconds then turn back ON. Usually connects to the nearest signal.
Crasje
Mar 18, 2025Tutor
Every time you move through the house when it should automaticly switch access point?
Wow.... with my RBR50 I never had this, handover were automatic and seamless.
- FURRYe38Mar 18, 2025Guru - Experienced User
Depends on how the device interprets the signal, noise and strength. The device handles the roaming algorithm.
Wifi5 differs from WiFI6 and 7.
- CrasjeMar 18, 2025Tutor
My router is on the ground floor, I have a satelitte on the 1st and 2nd floor. I am actually 5 meters away from the 2nd floor satelitte, yet for some reason my iPhone was connected to the router.
That is weird is it not? I had 1-2 bar coverage (download speed 40mb/s), restarted the phone, connected this time to the 2nd floor satellite and had 5 bars (download speed 750 mb/s)..
The algorithm should have handed me over?
I have the iPhone 16 pro, can it be I have to change some of the setting of the router config?
Would have to ask Apple about that. Been lots of post regarding newer models Apple phones having odd issues with WiFi7 systems.
