john_j
Dec 11, 2025Tutor
Orbi 870 -and Disney+ problems
Hi, I replaced my Fritzboxes with an Orbi 870 Mesh and since then I have not been able to use Disney+: Internet via Vodafone VDSL Draytek Vigor 167 as modem (nothing configured, just plugged in a...
- Dec 12, 2025
OK, here`s the solution: I called Disney and the friendly helpdesk added my IP address to my account. Now everything works fine - let`s see how long, as the IP is not a static one.
BTW - I don`t think that there could be a problem with the Modem ore double-NAT, as everything else works fine and doesn't show any signs of double-NAT.Thanks for your help - I will keep you informed, if anything changes.
Dec 11, 2025Guru - Experienced User
Does putting a PC or device in the RBRs DMZ change anything?
What happens if you set the modem for PPPoE and it the modem handle the PPPoE connection, then change the RBR to use DHCP for the WAN side connection?
Are you using ISP detected DNS or custome DNS on the RBR?
I would keep IPv6 disabled for now on the RBR.
What firmware version is on the Orbi system?
