john_j
Dec 11, 2025Tutor
Orbi 870 -and Disney+ problems
Hi, I replaced my Fritzboxes with an Orbi 870 Mesh and since then I have not been able to use Disney+: Internet via Vodafone VDSL Draytek Vigor 167 as modem (nothing configured, just plugged in a...
- Dec 12, 2025
OK, here`s the solution: I called Disney and the friendly helpdesk added my IP address to my account. Now everything works fine - let`s see how long, as the IP is not a static one.
BTW - I don`t think that there could be a problem with the Modem ore double-NAT, as everything else works fine and doesn't show any signs of double-NAT.Thanks for your help - I will keep you informed, if anything changes.
Dec 11, 2025Guru - Experienced User
Some of those services don't play nicely with a double nat. The Draytek Vigor 167 is a modem/router combo device. you might try putting the Orbi into the vigor's dmz so its not acting as a router along with the orbi.
I didn't see any evidance of this model having a router built in:
https://www.draytek.co.uk/products/business/vigor-167#specifications
