john_j
Dec 11, 2025Tutor
Orbi 870 -and Disney+ problems
Hi, I replaced my Fritzboxes with an Orbi 870 Mesh and since then I have not been able to use Disney+: Internet via Vodafone VDSL Draytek Vigor 167 as modem (nothing configured, just plugged in a...
- Dec 12, 2025
OK, here`s the solution: I called Disney and the friendly helpdesk added my IP address to my account. Now everything works fine - let`s see how long, as the IP is not a static one.
BTW - I don`t think that there could be a problem with the Modem ore double-NAT, as everything else works fine and doesn't show any signs of double-NAT.Thanks for your help - I will keep you informed, if anything changes.
john_j
Dec 12, 2025Tutor
OK here`s an update:
- using 8.8.8.8 and 1.1.1.1 as DNS -> same error
putting an Apple TV into DMZ -> same error
Netflix, Amazon and Apple TV work fine, btw...
- FURRYe38Dec 12, 2025Guru - Experienced User
Can you check with your ISP to see if this model modem doesn't have any router built in, if it does, then ask them to fully bridge the modem?
