john_j
Dec 11, 2025Tutor
Orbi 870 -and Disney+ problems
Hi, I replaced my Fritzboxes with an Orbi 870 Mesh and since then I have not been able to use Disney+: Internet via Vodafone VDSL Draytek Vigor 167 as modem (nothing configured, just plugged in a...
- Dec 12, 2025
OK, here`s the solution: I called Disney and the friendly helpdesk added my IP address to my account. Now everything works fine - let`s see how long, as the IP is not a static one.
BTW - I don`t think that there could be a problem with the Modem ore double-NAT, as everything else works fine and doesn't show any signs of double-NAT.Thanks for your help - I will keep you informed, if anything changes.
john_j
Dec 12, 2025Tutor
Maybe all Draytek or Orbi users are suspects :-)
- FURRYe38Dec 12, 2025Guru - Experienced User
Ya could be Disney and there security.
Ya but if "Netflix, Amazon and Apple TV work fine" then kind points to Disney as sus. :oP
Hopefully mostlly fixed for you. If it seems so, mark your thread as solved so others will know.
