rowp's avatar
rowp
Follower
Jul 22, 2026
Orbi 870 Firmware Updates
It seems the last firmware update was in the later half of 2025 i.e. Sep/October.
Just wondering if another one is planned soon? 1 year between updates seems like an awfully long time.
Does anyone have knowledge on when the next 870 update will be / what it should address?
I noticed one of my nodes backhaul degrades over time - I manually restart it from time to time but I hope there is a firmware fix.
1 Reply
  • FURRYe38's avatar
    NG doesn't give out time frames on when new FW is forth coming or what it addresses.
    New FW may not solve what users seen on there systems, there are other factors that can cuase issues that FW may not fix.
    Give more details of the issues at hand.
    What have you done to troubleshoot the issues at hand.
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
