DTN01
Aug 18, 2025Aspirant
Orbi 870 WAN performance
Hi Netgear team, I’ve recently purchased the Orbi 870 system, primarily due to its advertised support for 10Gbps WAN connections. I’m currently on a 10Gbps fibre plan and have the Orbi connected ...
DTN01
appreciate you taking the time to share this.
I totally get the point around Ethernet overhead and that we’ll never see a “true” 10.00Gbps line rate. That’s expected. I’m not chasing perfection here just trying to figure out why my Orbi 870 is consistently capped around 4.5Gbps on the built-in speed test, even under what I’d consider ideal conditions.
Ive run multiple speed tests directly from the ONT & Firewalla, bypassing the router, and those easily hit 9+Gbps so I know the connection is solid.
But when I use the Orbi’s internal speed test, I never see more than ~4.5Gbps, even at off-peak hours. This has been sustained for a week.
I’ve reached out to Netgear Support though it’s through a third-party distributor in my country, so I’m still waiting on a response. Thought I’d also ask here in case anyone else has run into the same thing.
The bigger question I’m trying to answer is this:
Is the Orbi 870 hardware-limited in such a way that it simply can’t push more than ~4.5–5Gbps on the WAN side, even under perfect conditions?
If there’s a technical reason why that’s not possible with this model, I think a lot of us would benefit from knowing that up front. It’s not a complaint just looking for clarity so I know whether to hang onto the system or go a different route.
