DTN01
Aug 18, 2025Aspirant
Orbi 870 WAN performance
Hi Netgear team, I’ve recently purchased the Orbi 870 system, primarily due to its advertised support for 10Gbps WAN connections. I’m currently on a 10Gbps fibre plan and have the Orbi connected ...
Aug 19, 2025Guru - Experienced User
What are the speeds seen on the Mac using Ooklas Installable speed test app on the Mac?
What brand and model# is the ONT?
Is the CAT7 cable UTP or STP?
Possible the test service being picked by Orbi may not be supporting of 10Gb or service is busy.
DTN01
Aug 19, 2025Aspirant
Hitting almost constant 9.1Gb via the Nokia ONT.
- FURRYe38Aug 19, 2025Guru - Experienced User
What model# is the ONT?
When testing direct to the ONT, which test server are you picking?
- FURRYe38Aug 22, 2025Guru - Experienced User
