DTN01
Aug 18, 2025Aspirant
Orbi 870 WAN performance
Hi Netgear team, I’ve recently purchased the Orbi 870 system, primarily due to its advertised support for 10Gbps WAN connections. I’m currently on a 10Gbps fibre plan and have the Orbi connected ...
CrimpOn
Aug 19, 2025Guru - Experienced User
Thanks for this information. On my RBR50 system, the results are in the folder "tmp" in a file "ookla_speedtest_result" (not ".txt", but clearly a text file)
serverid: 14236
isp: Spectrum
latency: 12
jitter: 0.26
upload: 12239
packet loss: 0.32%
Server 14236 is hosted by Frontier in Los Angeles, CA.
Perhaps the 870 router records more information. i.e.
TC_in_Montana wrote:also be able to see if you had some drops of speed during the tests
- TC_in_MontanaAug 20, 2025Virtuoso
The format/location/data is a bit improved in the later series (later than RBR50).
Here's a cut/paste from mine...
[2025-08-19 19:35:04.940] [info] Ping 1: 42.09 ms (42.09ms min, 0.00ms jitter)
[2025-08-19 19:35:04.988] [info] Ping 2: 47.10 ms (42.09ms min, 5.01ms jitter)
[2025-08-19 19:35:05.024] [info] Ping 1: 55.08 ms (55.08ms min, 0.00ms jitter)
[2025-08-19 19:35:05.032] [info] Ping 3: 44.54 ms (42.09ms min, 3.79ms jitter)
[2025-08-19 19:35:05.032] [info] Final Ping: 42.09 ms
[2025-08-19 19:35:05.033] [info] Stage 1 completed
[2025-08-19 19:35:05.045] [info] Ping 1: 66.18 ms (66.18ms min, 0.00ms jitter)
[2025-08-19 19:35:05.076] [info] Ping 2: 52.70 ms (52.70ms min, 2.39ms jitter)
[2025-08-19 19:35:05.079] [info] Ping 1: 58.99 ms (58.99ms min, 0.00ms jitter)
[2025-08-19 19:35:05.085] [info] Ping 1: 71.22 ms (71.22ms min, 0.00ms jitter)
[2025-08-19 19:35:05.087] [info] Ping 1: 58.39 ms (58.39ms min, 0.00ms jitter)
[2025-08-19 19:35:05.090] [info] Ping 1: 52.82 ms (52.82ms min, 0.00ms jitter)
[2025-08-19 19:35:05.091] [info] Ping 1: 53.52 ms (53.52ms min, 0.00ms jitter)
[2025-08-19 19:35:05.112] [info] Ping 2: 67.13 ms (66.18ms min, 0.95ms jitter)
[2025-08-19 19:35:05.133] [info] Ping 3: 56.91 ms (52.70ms min, 3.30ms jitter)
[2025-08-19 19:35:05.133] [info] Final Ping: 52.70 ms
[2025-08-19 19:35:05.133] [info] Stage 1 completed
[2025-08-19 19:35:05.141] [info] Ping 2: 61.93 ms (58.99ms min, 2.94ms jitter)
[2025-08-19 19:35:05.142] [info] Ping 2: 52.05 ms (52.05ms min, 0.77ms jitter)
[2025-08-19 19:35:05.143] [info] Ping 2: 51.83 ms (51.83ms min, 1.69ms jitter)
[2025-08-19 19:35:05.146] [info] Ping 2: 58.98 ms (58.39ms min, 0.60ms jitter)
[2025-08-19 19:35:05.158] [info] Ping 2: 72.85 ms (71.22ms min, 1.63ms jitter)
[2025-08-19 19:35:05.163] [info] Ping 1: 38.88 ms (38.88ms min, 0.00ms jitter)
[2025-08-19 19:35:05.180] [info] Ping 3: 67.92 ms (66.18ms min, 0.87ms jitter)
[2025-08-19 19:35:05.180] [info] Final Ping: 66.18 ms
[2025-08-19 19:35:05.180] [info] Stage 1 completed
[2025-08-19 19:35:05.183] [info] Ping 1: 55.88 ms (55.88ms min, 0.00ms jitter)
[2025-08-19 19:35:05.193] [info] Ping 3: 50.77 ms (50.77ms min, 1.03ms jitter)
[2025-08-19 19:35:05.193] [info] Final Ping: 50.77 ms
[2025-08-19 19:35:05.193] [info] Stage 1 completed
[2025-08-19 19:35:05.195] [info] Ping 3: 51.80 ms (51.80ms min, 0.86ms jitter)
[2025-08-19 19:35:05.195] [info] Final Ping: 51.80 ms
[2025-08-19 19:35:05.195] [info] Stage 1 completed
[2025-08-19 19:35:05.203] [info] Ping 2: 39.82 ms (38.88ms min, 0.94ms jitter)
[2025-08-19 19:35:05.203] [info] Ping 3: 61.80 ms (58.99ms min, 1.53ms jitter)
[2025-08-19 19:35:05.203] [info] Final Ping: 58.99 ms
[2025-08-19 19:35:05.203] [info] Stage 1 completed
[2025-08-19 19:35:05.205] [info] Ping 3: 58.77 ms (58.39ms min, 0.40ms jitter)
[2025-08-19 19:35:05.205] [info] Final Ping: 58.39 ms
[2025-08-19 19:35:05.205] [info] Stage 1 completed
[2025-08-19 19:35:05.231] [info] Ping 3: 72.82 ms (71.22ms min, 0.83ms jitter)
[2025-08-19 19:35:05.231] [info] Final Ping: 71.22 ms
[2025-08-19 19:35:05.232] [info] Stage 1 completed
[2025-08-19 19:35:05.239] [info] Ping 2: 55.83 ms (55.83ms min, 0.06ms jitter)
[2025-08-19 19:35:05.242] [info] Ping 3: 38.87 ms (38.87ms min, 0.94ms jitter)
[2025-08-19 19:35:05.242] [info] Final Ping: 38.87 ms
[2025-08-19 19:35:05.242] [info] Stage 1 completed
[2025-08-19 19:35:05.295] [info] Ping 3: 55.94 ms (55.83ms min, 0.08ms jitter)
[2025-08-19 19:35:05.295] [info] Final Ping: 55.83 ms
[2025-08-19 19:35:05.295] [info] Stage 1 completed
[2025-08-19 19:35:05.297] [info] server selected: 5856
[2025-08-19 19:35:05.297] [info] Server id: 5856
[2025-08-19 19:35:05.297] [info] Name: Billings, MT
[2025-08-19 19:35:05.297] [info] Country: United States
[2025-08-19 19:35:05.297] [info] Asn:
[2025-08-19 19:35:05.297] [info] Sponsor: Spectrum
serverid: 5856
isp: Spectrum
[2025-08-19 19:35:05.297] [info] Running TCP test suite
[2025-08-19 19:35:05.310] [info] Running Speedtest against host:port blngmt-speedtest-ookla-01.st.charter.com:8080
[2025-08-19 19:35:05.310] [info] Starting stage 1 of type 2
[2025-08-19 19:35:05.335] [info] Resolved address 1: 69.144.192.154
[2025-08-19 19:35:05.335] [info] Resolved address 2: 2600:6c66:0:8::6:2
[2025-08-19 19:35:05.335] [info] Opening socket to '69.144.192.154'
[2025-08-19 19:35:05.390] [info] Ping 1: 8.88 ms (8.88ms min, 0.00ms jitter)
[2025-08-19 19:35:05.399] [info] Ping 2: 8.84 ms (8.84ms min, 0.04ms jitter)
[2025-08-19 19:35:05.408] [info] Ping 3: 8.82 ms (8.82ms min, 0.03ms jitter)
[2025-08-19 19:35:05.418] [info] Ping 4: 10.03 ms (8.82ms min, 0.42ms jitter)
[2025-08-19 19:35:05.427] [info] Ping 5: 8.80 ms (8.80ms min, 0.62ms jitter)
[2025-08-19 19:35:05.427] [info] Final Ping: 8.80 ms
[2025-08-19 19:35:05.427] [info] Stage 1 completed
latency: 8
jitter: 0.62
[2025-08-19 19:35:05.428] [info] Starting stage 2 of type 4
[2025-08-19 19:35:06.429] [info] Upload test: Received 4481560 bytes 6% complete 4973984 bytes/sec avg
[2025-08-19 19:35:07.429] [info] Upload test: Received 5163568 bytes 13% complete 5071045 bytes/sec avg
[2025-08-19 19:35:08.429] [info] Upload test: Received 4940576 bytes 19% complete 4998546 bytes/sec avg
[2025-08-19 19:35:09.429] [info] Upload test: Received 5099856 bytes 26% complete 5032712 bytes/sec avg
[2025-08-19 19:35:10.429] [info] Upload test: Received 4994152 bytes 33% complete 5013729 bytes/sec avg
[2025-08-19 19:35:11.430] [info] Upload test: Received 5111440 bytes 39% complete 5036648 bytes/sec avg
[2025-08-19 19:35:12.430] [info] Upload test: Received 5085376 bytes 46% complete 5043647 bytes/sec avg
[2025-08-19 19:35:13.430] [info] Upload test: Received 5010080 bytes 53% complete 5051587 bytes/sec avg
[2025-08-19 19:35:14.430] [info] Upload test: Received 5173704 bytes 59% complete 5059404 bytes/sec avg
[2025-08-19 19:35:15.430] [info] Upload test: Received 4973880 bytes 66% complete 5063252 bytes/sec avg
[2025-08-19 19:35:16.431] [info] Upload test: Received 5121576 bytes 73% complete 5067334 bytes/sec avg
[2025-08-19 19:35:17.431] [info] Upload test: Received 5020216 bytes 79% complete 5066335 bytes/sec avg
[2025-08-19 19:35:18.431] [info] Upload test: Received 5083928 bytes 86% complete 5077072 bytes/sec avg
[2025-08-19 19:35:19.431] [info] Upload test: Received 5115784 bytes 93% complete 5077943 bytes/sec avg
[2025-08-19 19:35:20.432] [info] Upload test: Received 5092616 bytes 99% complete 5079608 bytes/sec avg
[2025-08-19 19:35:21.432] [info] Stage 2 completed
[2025-08-19 19:35:21.432] [info] Upload test: Received 467704 bytes 100% complete 5079732 bytes/sec avg
upload: 40637
[2025-08-19 19:35:21.432] [info] Starting stage 3 of type 3
[2025-08-19 19:35:21.482] [info] Packet loss sent=319, received=311, dupes=0, maxId=318
[2025-08-19 19:35:21.498] [info] Resolved address 1: 192.161.70.17
[2025-08-19 19:35:21.498] [info] Resolved address 2: 2604:ff40:0:300::5
[2025-08-19 19:35:21.498] [info] Opening socket to '192.161.70.17'
[2025-08-19 19:35:21.519] [info] Resolved address 1: 63.224.243.198
[2025-08-19 19:35:21.519] [info] Opening socket to '63.224.243.198'
[2025-08-19 19:35:21.527] [info] Resolved address 1: 158.120.47.243
[2025-08-19 19:35:21.527] [info] Resolved address 2: 2604:9440:2301::5060
[2025-08-19 19:35:21.527] [info] Opening socket to '158.120.47.243'
[2025-08-19 19:35:23.433] [info] Download test: Received 149079752 bytes 9% complete 102943615 bytes/sec avg
[2025-08-19 19:35:24.434] [info] Download test: Received 124029688 bytes 16% complete 111542214 bytes/sec avg
[2025-08-19 19:35:25.434] [info] Download test: Received 130500288 bytes 22% complete 118662038 bytes/sec avg
[2025-08-19 19:35:26.434] [info] Download test: Received 157039944 bytes 29% complete 132175263 bytes/sec avg
[2025-08-19 19:35:27.434] [info] Download test: Received 105967181 bytes 36% complete 125845031 bytes/sec avg
[2025-08-19 19:35:28.435] [info] Download test: Received 148599888 bytes 42% complete 131339020 bytes/sec avg
[2025-08-19 19:35:29.435] [info] Download test: Received 134401176 bytes 49% complete 132529176 bytes/sec avg
[2025-08-19 19:35:30.435] [info] Download test: Received 122007768 bytes 56% complete 131775833 bytes/sec avg
[2025-08-19 19:35:31.435] [info] Download test: Received 128369544 bytes 63% complete 131752714 bytes/sec avg
[2025-08-19 19:35:32.435] [info] Download test: Received 117212704 bytes 69% complete 132076633 bytes/sec avg
[2025-08-19 19:35:33.436] [info] Download test: Received 110575072 bytes 76% complete 131910462 bytes/sec avg
[2025-08-19 19:35:34.436] [info] Download test: Received 152870800 bytes 83% complete 132770091 bytes/sec avg
[2025-08-19 19:35:35.436] [info] Download test: Received 138076936 bytes 89% complete 133114148 bytes/sec avg
[2025-08-19 19:35:36.437] [info] Download test: Received 111957912 bytes 96% complete 133274745 bytes/sec avg
[2025-08-19 19:35:37.094] [info] Stage 3 completed
[2025-08-19 19:35:37.094] [info] Download test: Received 152668432 bytes 100% complete 133996811 bytes/sec avg
[2025-08-19 19:35:37.097] [info] final result - serverid: 5856 ping: 9 download: 1071974 upload: 40637
[2025-08-19 19:35:37.097] [info] latency 9ms jitter: 0.62ms packet loss 2.51%
[2025-08-19 19:35:37.097] [info] total download bytes: 1983357085
[2025-08-19 19:35:37.097] [info] total download stage duration: 15107.765000 ms
[2025-08-19 19:35:37.097] [info] total upload bytes: 75936016
[2025-08-19 19:35:37.097] [info] total upload stage duration: 15017.000000 ms
